It will not matter where you put the hard drive as long as you secure it to avoid it falling over.
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
https://linustechtips.com/topic/167657-hard-drive-position/#findComment-2230428
No difference as long as it's secured.
If it's an SSD it makes no difference if you swing it from a SATA cable while you dance yankee doodle.
What do you think i should use to secure it.
https://linustechtips.com/topic/167657-hard-drive-position/#findComment-2230432
Velcro works well, as does electric tape if you don't care about the looks too much.
Desktop <dead?>
https://linustechtips.com/topic/167657-hard-drive-position/#findComment-2230435
You can rest it there as long as you are 100% sure it isn't going to move around.
Are we talking about behind the motherboard tray where the cable management area is or inside the main case compartment?
Behind the motherboard tray where the cable management area is.
https://linustechtips.com/topic/167657-hard-drive-position/#findComment-2230504
Hmm, I wouldn't put it there myself unless I had fashioned some kind of bracket or tray to hold it in place, I'd say as long as you secure it so that it feels sturdy to the hand you should be ok.
https://linustechtips.com/topic/167657-hard-drive-position/#findComment-2230533
