Hi all, i have a rosewill destroyer case with just the stock fans and i was wondering why after i removed the fan to clean the case, the fan is louder. it sounds as though it's vibrating against the case.
Is there something i can do to make it quieter or at least as quiet as it was before removing and replacing it?
https://linustechtips.com/topic/166845-very-loud-case-fan/
If you didn't use rubber grommets for the fan, try to get some and use them. They really do make a difference.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/166845-very-loud-case-fan/#findComment-2220370
thanks for the tip. what are common stores i can get some from?
pretty sure they sell them on amazon
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/166845-very-loud-case-fan/#findComment-2220672
I was hoping to find them in a local store if possible, otherwise i would order them. do you know of any?
Take fan screw and go to local hardware store and ask for o-rings that would fit the screw. Those are really basic but will do same effect as ordering $5 pack from amazon.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/166845-very-loud-case-fan/#findComment-2222409
Unless you live in Manchester I won't know any local shops lol
https://linustechtips.com/topic/166845-very-loud-case-fan/#findComment-2222521
