Hi
I am looking to buy a new sound system for my pc.
I am looking for buying headphones and a DAC (as far as I can tell from reading up online this is a far better option then a sound card. but if you have experience, and you think that this will not be an advantage, or maybe some other solution is better, please suggest.)
I am currently using a Asus ROG Formula VI with the onboard sound card.
I want this mostly for playing games, and I want good positioning and high quality music. I also listen to some music, but gaming is the priority as far as specs.
Also I need for the headphones to be light and comfortable, since I will be using them for long periods of time. I also prefer headphones that can cancel out the background noise, but I don't want to lose sound quality for some fancy active noise cancellation.
I am looking for a budget of $450 but if something is a lot better for a bit more money I am willing to go for it.
Thanks
Intel 4770k   -   Corsair Vengeance Pro CL9 16gb 1866mhz   -   Corsair Air 540   -   Gentle Typhoon AP45   -   Corsair ax1200i   -   Razer Death Adder 2013   -   Filco Majestouch 2   -   Crucial m4 256gb ssd   -   1TB Western Digital Black   -   Asus Maximus vi Formula   -   Bitspower matte black fittings   -   Black Ice sr1 240mm and 360mm Radiators   -   Swiftech mcp655   -   EK x-res pump top   -   Promochill Advanced lrt 3/8 5/8 bloodshed red tubing   -   swiftech apogee hd cpu block   -   Asus pb278q 1440p monitor   -   Razer Carcharas Headphones   -   Razer Vespula Hard Mouse Pad   -   Arctic Silver 5 TIM   -   Sapphire r9-290x   -   Ek-fc R9-290x Waterblock and Backplate
https://linustechtips.com/topic/166437-recommend-a-sound-system/
Beyerdynamic Dt990 + O2+ODac Amp/DAC Combo. Solid choice for gaming and music with good positional accuracy as well as great highs, mid and solid bass.
New PC Build - Build Log - http://linustechtips.com/main/topic/276039-project-swift-force/
[spoiler=]
  • Case: Phanteks Enthoo Primo
  • Motherboard: Asus Maximus VII Hero
  • CPU: Intel i7-4790K
  • GPU1: GIGABYTE G1 GAMING GTX 970 4GB
  • GPU2: GIGABYTE G1 GAMING GTX 970 4GB
  • RAM: Corsair Vengeance Pro Red, 16gb (2x8GB) @1600mhz
  • PSU: EVGA SuperNova 850W 80+ Gold
  • CPU Cooler: NZXT Kraken X61
  • HDD: Seagate Barracuda - 2TB 7200RPM
  • SSD: Samsung 840 EVO - 250GB
  • Monitor: Asus PG278Q ROG Swift 27" 144hz G-Sync
  • Headphones: Beyerdynamic DT990 Pro 600 OHM
  • DAC/AMP: Mayflower Objective2 + ODAC Combo
  • Mouse: ROCCAT Kone Pure Optical
  • Keyboard: KBP V60 - Cherry MX Brown
https://linustechtips.com/topic/166437-recommend-a-sound-system/#findComment-2215206
I'd have recommend the HE400. Those big planar drivers really put depths in gaming positional sound. But the HE400 is a bit uncomfortable if you haven't got used to it. Weighs 480g, due to its big planar magnets. Superb for music and gaming though....
https://linustechtips.com/topic/166437-recommend-a-sound-system/#findComment-2215232
You should not spend 2x on the amp than the headphone.
OP go for HE400 with o2 amp or Fostex T50rp with o2 amp. There is also an o2/odac combo unit for pretty cheap on Massdrop right now if you want to spend the extra money for it.
Edit: oh wait you said light. The 2 headphone I mentioned are a bit heavy because they are planers but they sound much better than non planers. You can go for Dt770/990 for some lighter headphones and mayyyybe an amp but you would get better sound if you got planers. Another option is Sennheiser HD650 but the Sennheiser design is uncomfortable for big heads.
https://linustechtips.com/topic/166437-recommend-a-sound-system/#findComment-2215268
The DT990's are $200-350. Same as the HE400.
Yet you still recommend the o2/odac combo, lol.
[spoiler=]
https://linustechtips.com/topic/166437-recommend-a-sound-system/#findComment-2215397
DT990 are $150 in the old Americaland. I wanted to shy away from the o2 for those because you're spending too much on the amp. If you're going to get an o2 for those, only go o2 standalone not the combo. I specifically said the combo only if you want to spend extra money.
https://linustechtips.com/topic/166437-recommend-a-sound-system/#findComment-2215480
What are your opinions on the akg k702/k701/ q701 and ad900?
I heard that these are great options
https://linustechtips.com/topic/166437-recommend-a-sound-system/#findComment-2215583
The AKGs are pretty good but I wouldn't recommend the AD900 for music. They are very neutral sounding. I personally still prefer planers over them with your budget. I've been told all 3 of those AKGs sound pretty much the same.
https://linustechtips.com/topic/166437-recommend-a-sound-system/#findComment-2215956
After doing additonal research I think I'm going for the dt990s and o2+odac combo (http://www.jdslabs.com/products/48/o2-odac-combo/)
Now my question is, is there really a difference between the pros and premium. As far as I can tell, the sound is exact same, but the premiums are more comfortable. Can you recommend me what to do, as comfort is extremely important to me.
Also, since I will be getting the o2 amp/odac combo anyway, I will have enough power, so should I get the 600ohm or 250ohm?
thanks again
https://linustechtips.com/topic/166437-recommend-a-sound-system/#findComment-2218565
Get whatever's cheapest. The headband is spring steel, so if you find it uncomfortable you can just bend it out.
https://linustechtips.com/topic/166437-recommend-a-sound-system/#findComment-2218973
thanks again
Just get the Pros. The premiums are not worth the $100 extra. Also if you want an o2 amp, get this
https://www.massdrop.com/buy/mayflower-dac
https://linustechtips.com/topic/166437-recommend-a-sound-system/#findComment-2218979
