I'm sure you're fine with that psu but personally, with a build like that I always like to get a 750w just for some extra room.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/166350-first-build-need-help/#findComment-2214058
What is you going to use it for?
and buy a cable for networking (I did buy a wireless networking card but i only got problem with it so..)
and get a z97, it bettere and common got sata express and some other things like it cost less
CPU: Intel Core i5-4670K Cooler: Noctua NH-D15 Motherboard: Gigabyte GA-Z97X-UD3H-BK RAM: Kingston Beast 8GB (2 x 4GB) SSD: Samsung 840 EVO 120GB HHD Western Digital Caviar Blue 1TB GPU Asus GeForce GTX 770 2GB CASE: Fractal Design Define R4 PSU: Corsair RM 550W OS: Windows 8.1 Wireless network: Asus pce-n53 (Broken)
https://linustechtips.com/topic/166350-first-build-need-help/#findComment-2214063
mainly for gaming. could do video editing in the future though.
https://linustechtips.com/topic/166350-first-build-need-help/#findComment-2214293
