Afaik tk doesn't have separated arrow and num pad and the pro does
And why is tk more expensive than the pro?
Both have:
led backlit
Nkro
Correct me if I am wrong, thanks :)
i5 3470 | MSI B75MA P45 | 8GB Value Ram | Plextor M5S 128GB | Sapphire 7850 | WD Blue 1TB | SF 600W Gold | CM Storm Scout II
https://linustechtips.com/topic/16589-cm-storm-tk-or-pro/
 the pro has only partial lighting that the only price difference i could see that made any ounce of sense
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/16589-cm-storm-tk-or-pro/#findComment-189209
I'm not sure why it is more expensive but I can vouch for the quickfire pro. It's a nice, sturdily built keyboard, but I'm kinda over the styling, my girlfriend just got a ducky shine 2, and I want it so bad, even though it has pink leds :P
Can you adjust the brightness and have like pulse lighting?
https://linustechtips.com/topic/16589-cm-storm-tk-or-pro/#findComment-189275
i had the Cm storm Pro, yes you can switch mode to breathing but i would recommend you the TK and not the Pro
Why? What do you hate about the pro?
Personally i like the TK better, backlighting is sexy but half backlighting is definitely a neigh.
How's half backlighting like? I've never own a keyboard like these
https://linustechtips.com/topic/16589-cm-storm-tk-or-pro/#findComment-189451
Thanks I will get the tk then
Good choice, the TK is simply secksay! I have it on my 3rd rig, use it mostly for gaming, and I tend to do more typing on it.20130507_153256_zps528b1051.jpg
Heh, if you like the Ducky Shine II with pink LED, what do you think of this?
I'd gotten this on impulse, wasn't my intention to buy it, but when it was plugged in and the LED came on, I simply couldn't walk away. Besides, that it is a limited edition KB made it all the more.......desirable! Mine's 210/399 btw,,,
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/16589-cm-storm-tk-or-pro/#findComment-189677
