Done. The things i did so far were:
Run as admin
Try to delete licenses (but i don't have a C:\ProgramData folder so that doesn't work for me)
Disable anti virus
Try looking for the process in task manager and ending it.
"When in doubt, don't take your wallet out." - Dad
† TTCF Member †
I'd try reinstalling the game.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
Tried. Didn't work.
I would assume that the C++ libraries that the game uses were reinstalled when you reinstalled the game, but you might want to uninstall those and then reinstall them.  You should be able to uninstall them, then they should be reinstalled the next time the game is started if I remember correctly.
what are those?
Samung Tab S 8.4
what are those?
If you go into Control Panel>Add/Remove Programs you will likely see something like the picture below.  I don't know what likelihood is that those would be causing the problem though.
post-37426-0-26561300-1402670775_thumb.p
