I have a small case but it has ALOT of vent holes on all sides. Would it be a good idea to turn all fans in to have a lot of positive pressure in? To me it seems like there is enough vent holes that I don't need a fan blowing out. I'm new to this so let me know if this is a bad idea
https://linustechtips.com/topic/164253-small-case-positive-pressure/
I'm pretty sure having at least one fan blowing out is a good idea. If it is only passively being transferred out of the case, it won't be as effective, and the ambient temperature will warm up. Preferably, have a fan blowing out on the top of the case, because heat rises.
Build: CPU: Intel Core i5 4690k | CPU Cooler: Hyper 212 Evo | Motherboard: MSI Z97 Gaming 5 | RAM: 8GB G-Skill Ares 1600Mhz CL9 | Storage: 120GB Samsung 840 Evo + WD Blue 1TB 64MB Cache + Seagate Barracuda 2TB 64MB Cache | GPU: MSI GTX 960 | Case: Cooler Master Storm Enforcer | Power Supply: EVGA 600B Non-Modular |
"a small case"
Can't really help you unless you tell us exactly what your case is, because there may be other factors such as HDD/mobo placement and cables in the way that we don't know about.
That is, unless you have a SG05 where the only possible exhaust is the SFX PSU.
Since we are talking about custom case which hasn't really stated where current fans are, its bit difficult to imagine what airflow would be optimal. Generally you want side-front-bottom intake and top-rear exhaust to get best airflow going on. There however depend highly on what kind of CPU cooling is used and where does it locate.
From pics I saw the CPU has 120mm AIO cooling. If that rad has one fan which is set to exhaust, then every other fan should intake. I think that rad could be set as intake also but that might make GPU hotter unless it has own fresh intake.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
