First Build Front USB Issue
Go to solution Solved by dragoon20005,
Hey guys. I just finished my first build today. For reference, fractal design define r4 case and Asus Maximus vii ranger motherboard.
On the first bootup, everything worked fine, and I plugged my mouse into every usb port to ensure they were working - and they were. After proceeding to download all drivers and OS obviously, the 2 front usb 2.0 ports do not seem to be working. All other usb 2.0/3.0 ports do however work. Just not the front 2 usb 2.0
i have tried different headers all to no avail, so any help is appreciated.
you might need to access the BIOS to activate the USB headers
refer to  chapt 3-page 35 of you mobo manual
"The only person you are destined to become is the person you decide to be."
CPU: Intel i5 4690K - Motherboard: Asus Maximus VII Ranger - RAM: Corsair Vengeance LP - 2x4GB @ 1866Mhz - GPU: MSI Twin Frozr GTX 770 4GB - CPU Cooler: Be Quiet! Dark Rock Pro 3 CPU Cooler - PSU: EVGA SuperNova G2 750W - Storage: Seagate Barracuda 2TB HDD- Case: Fractal Design Define R4 Windowed (with Red AKASA Led Strips) - Display: Benq GL2460HM 24" Monitor
https://linustechtips.com/topic/164228-first-build-front-usb-issue/
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Hey, thanks for the reply.  I got it sorted, front panel connections somehow became loose, not from motherboard but from the other end. Fixed the problem.
As a side note. my 1866 mhz corsair vengeance lp ram only shows up as 932.5 mhz on CPU-Z although i've changed it in bios. Any ideas why that may be?
http://www.overclock.net/t/1346124/cpu-z-shows-ram-at-half-speed
its normal DDR means double data rate
932.5 x 2 = 1866
932.5 x 2 = 1866
Ah okay thanks. My timings are 9-10-9-27, is that okay?
cant tell for sure but check the exact spec of your RAM for the CAS latency
Okay, got it. Thank you for the help, much appreciated.
