case fan direction ?
Go to solution Solved by Oshino Shinobu,
Flip the bottom fan to intake, but put a filter there if you don't already have one.
This. It's the only change I'd make.
The reason it's usually this:
Front - Intake
Bottom - Intake
Back - Exhaust
Top - Exhaust
Sides - Intake
Is because that makes the most sense considering how heat acts in a liquid (air is a liquid). It rises. The reason it's front to back is because all the heat generating things (mostly) are in the back. PSU's push air backwards and you can't change those without removing the PSU or flipping it over (bottom mounted only though) for intake.
Basically, it is how most case designers already build into the case, so it's easiest to "go with the flow" (pun intended).
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/164126-case-fan-direction/#findComment-2183510
If you can fit a fan intaking on the bottom while you have the radiator like in the last pic I would do that otherwise id be tempted to have it like the bottom picture.
My Rig : Zotac 780 3GB, i5 4670k, H105, M1211 650W, 8GB 2133mhz vengence pro, Mini R2, 144Hz AOC Gsync Monitor
Accessories : K65, Naos 3200, Superlux 681, Chord CCU1
https://linustechtips.com/topic/164126-case-fan-direction/#findComment-2183519
will do thank's
I'll see if I can mount a fan how minicale, described.
but i think it wont fit, unless i tilt it a little bit.
will see, thanks
https://linustechtips.com/topic/164126-case-fan-direction/#findComment-2183577
