First water cooled build
Solved by SpyRosL,
If you are not planning on overclocking any 360mm rad would be perfect and then in the future maybe another 240mm for superior cooling. The thicker,the better ![]()
As for the fans,the best hands down are the noctuas NF-F12s but if you find them expensive or ugly another excellent choice is the corsair SP120s or silverstone Air penetrators.
