Hello, i just finished my new build . 265k on asus board, msi 5070 32ddr5 ram. The only game i play is Arc-raiders.  Im having issues w EAC
this is event viewer error Session "dc3a3596-71e1-45a3-b2ea-39ad5322fe51" failed to start with the following error: 0xC0000022.
All drivers, BIOS, up to date. I have tried repair EAC, check file integrity. Pretty much every tip i can find online.  About 25min of gaming the game would freeze. Event viewer keeps givjng the above error over over again.
Any idea how to resolve this?
https://linustechtips.com/topic/1636789-easy-anti-cheat-issue/
0xC0000022 is like permission problems for an app, a process to run I think.
Do you play as a regular user or an Admin user? If regular try the game as an Admin.
You can also try go to the EAC exe file, right click into Properties and into Compatibility tab. In there should be a checkbox to run as an Admin that you can check.
I usually edit my posts.
Refresh the page before answering to my post.
https://linustechtips.com/topic/1636789-easy-anti-cheat-issue/#findComment-16894904
