Hey, so im pretty new to understanding cpu comparisons and how to actually understand benchmarks.
Right now im comparing two specific cpus:
Intel Core i7 13620H
Intel Core i5 13420H
Ive gone over the comparison stats on the following websites, and I can see that the difference isnt very big, but could someone help me out and explain if the difference is really not that much or am I reading it incorrectly:
https://nanoreview.net/en/cpu-compare/intel-core-i7-13620h-vs-intel-core-i5-13420h
https://cpu.userbenchmark.com/Compare/Intel-Core-i5-13420H-vs-Intel-Core-i7-13620H/m2088006vsm2049481
https://www.cpubenchmark.net/compare/5434vs5283/Intel-i5-13420H-vs-Intel-i7-13620H
Id appreciate any help i can get, thanks!!
https://linustechtips.com/topic/1636696-need-help-comparing-two-cpus/
Correct, it's not much difference. 2 more cores, a little more cache etc.
If you need more cores for production work, get the 13620H but otherwise they're only about 10-15% performance difference.
CPUs are all much closer than you think, they don't have massive gaps to keep them all separate.  It's why you'll see some people recommend a 5600 vs a 5700X for gaming, or a 9600X vs a 9800X3D depending on resolution.
Reall though, what are you going to use the CPU for?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Tbh, it's quite a lot of difference against, say, higher clock speeds🤓
*using non-conversational, sketch-level language to gesture at structure and direction.
The GB8/12 Liberation Front
Yeah, but for certain uses it just isn't.  I'd recommend comparing them directly in specific use cases, as productivity may be a decent difference but gaming may only be 10-15% max.
OnePlus Ecosystem:
3D Printing:
hi, thanks for the input!!!!
Well the reason im comparing both of them is that i was considering buying a laptop, but the i7 model that i wanted to buy was sold out. it was an i7 model with 32gb of ddr5 ram and 1tb of 2280 m.2 nvme ssd. an alternative i see is a i5 model with 16gb of ddr5 ram and 500gb of 2280 m.2 nvme ssd. the differences in the laptop prices and my budget, allow me to buy 16gb of ddr5 ram + 500gb of 2230 m.2 nvme ssd making them almost equal in specs (as the laptop has dual ram and storage ports), except the i5 vs the i7 issue.
in terms of usecases, i have never done video editing ( my last laptop was an i3 that could barely run photoshop so i never tried video editing), i intend to use photoshop pretty frequently and i dont game much. i might run some ml models locally, maybe something research oriented stuff at times as well.
my only intention in buying the i7 was that if i am upgrading for at least the next 4-5 (i know that is a big range), i dont want to be bottlenecked by my cpu.
I'll add a few more details.
I mainly intend to use the laptop for programming and running resource intensive apps like docker, vms etc. The laptop doesnt have a specific separate gpu but i would be intrested in running local llms on my cpu, if possible, for fun.
Otherwise the general usecase would be simple web browsing, using obsidian, reading pdfs etc. Like light stuff. But when needed i would be happy if it could perform the extreme compute i need.
Welcome to the forums!
Does the specific model you're looking at have user replaceable RAM? A lot of laptops I'm seeing these days don't. Also, does it have a spare M2 slot for that extra 500GB of storage?
yup. i chose this laptop specifically since it has two upgradable ram slots and two m.2 nvme slots (1 2230, 2280)
Well, you're missing out on some performance by getting the i5 and it probably won't hold its value as long, but with your usecase you don't really need more performance assuming you aren't trying to compile unholy massive projects. Also, I wouldn't have much confidence in the i7 model coming back in stock given how old the chip is.
then go for the i7.
as noted above, I-7 is best for productivity such as what you intend, I-5's are more than adequate for gaming if that is the main goal.
another qn guys, would 32gb of ram ever feel less?
like in terms of future proofing? i ask because if i buy a single 32gb ram, i can still upgrade, but if i buy two 16 gb rams, then im locked in that config and upgrading makes one of them useless
