I Changed my Cpu‘s Thermal Paste to artic mx6 and now it go worse. I changed back to the one i was given in the lian-li aio but its still the same bad results. Example My pc starts up with around 70°c and then goes down to 50°c. Starting minecraft with mods makes it spike up to 95°c. and being inside the world with no shaders and 6 render distance still keeps my cpu on 95°c.
https://linustechtips.com/topic/1634925-cpu-overheating/
that's not the paste. double check the mount. is it tight and snug?
have you checked the pump? any air in the lines?
I use MX6 and have had good results.
https://linustechtips.com/topic/1634925-cpu-overheating/#findComment-16883560
I have spring screws and they stop me from continue screwing if its tight enough. And before i had it a bit lose but still without any wiggles and still no changes
https://linustechtips.com/topic/1634925-cpu-overheating/#findComment-16883562
13 minutes ago, Hinjima said:
Did you plug the pump/fans back into the motherboard if you removed them?
The paste is not causing this, either mounting pressure is severely lacking or the pump is not working.
I never unplugged them, i gently moved it aside and had plenty room to clean it with 99.9% alc, and put paste on it
https://linustechtips.com/topic/1634925-cpu-overheating/#findComment-16883576
HOW did you apply the paste?  Did you use enough?  Is it spreading well?
It sounds like you are not applying it properly, if you say the cooler is mounted fine.  Not much else to account for.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1634925-cpu-overheating/#findComment-16883646
Yea, i put enough. Once even double the amount needed but still overheats quickly.
https://linustechtips.com/topic/1634925-cpu-overheating/#findComment-16883659
