cleaning method for LGA?
Go to solution Solved by danalog,
Take a small brush soaked in 95+% isopropyl, LIGHTLY clean along the pins. I recommend not using a Q-tip or cotton ball because they'll leave little fibers in the socket. Did that successfully to clean up some spilled paste. Likely you don't even need to do that though, probably could just blow the socket out with compressed air (not too close/forcefully!).
What is the best method to clean LGA? I guess I had a bad mount or something because the pc wouldnt post at all and I eventually determined cpu v_core was at 0.051v so i pulled it out and it had normal voltage empty so I just put it back in and it now works fine lol.
Is it just that its probably dirty? I find it kinda jank it shows issue now after 8 months later.
https://linustechtips.com/topic/1633516-cleaning-method-for-lga/
it's very low
probably dirty?
if there something visible
if not  it could be something in the circute or  the sensor or the cpu itself
if it's in warranty i suggest you RMA it if not if you could  request inspection from the manufacture
Edited by Mina G
fixed a lot of typos that i didn't notice
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
like a paint brush? or maybe i should stick to nylon
A little paint brush would do well yes
Works Cited
Before even doing that, it is working now? Voltage is normal now? If so, then don't touch it. You have higher risk damaging pins than any possible good that you think you will do.
it is but it did crash just now in a not normal way so idk. thermals seem fine after reusing the paste but i may pull it apart and at least wipe down the cpu side and repaste. the cpu was used off ebay and the mobo has seen like at least 8 cpu socketings at this point
Is it a new windows install? Have you tested the CPU on another system?
