Problems with an HDD
Solved by OhioYJ,
1 minute ago, XxK3V1NxX said:And what if there are multiple partitions, as in this case?
You have to do them individually.
Select 1, delete 1. Select 2, delete 2. And so on. You unfortunately have to do them one at a time.
You don't have to do them all, you can skip some, you can do them in any order. Delete just what you need to, or delete them all if you want. You will need to do them one at a time though.
