my NAS build finally taking the first step!
Snip
With de-duplication you can enable it when you create your dataset or zvol (its on one of them). I think you can enable it after you've made your zvol/dataset and got all your files sorted just don't hold me to that as i haven't used it yet.
If you go with the avaton board (its a good choice) you would be best off going with ECC ram an 8GB stick costs £60 on Amazon. check out the supermicro boards as well i hear really good things about them as well as the benefit of supporting a xeon processor.
If you go with freenas and ZFS 8GB is the minimum amount of ram that they recommend using. general rule of thumb is 6GB base + 1GB for every 1TB of storage.
with freenas you will need ZFS for plugins such as plex and transmission so its worth spending the extra £ for ZFS.
With Raid i am only using 1x 3TB HDD at the moment so im not well versed on this. But i believe zfs uses raidz (similar to raid 5 i think) you will need a minimum of 3 HDD's to achieve this. im not sure on this so check out the freenas forums they will probably correct me on a few things. linus has raid videos too. (when you make your ZFS it will auto select the best option in raid for your system)
Converting NFTS/Fat32 to a ZFS i highly doubt this is achievable. you would most likely have to format the drives before converting. once again check out the freenas forums on this. there is a really helpful Noob section.
