Hi there,
Looking for some help with ROG phone 5S, have done a tear down to replace front and back glass, all was going fine but I snapped one of the ribbon cables, after ordering replacement cable and new battery because why not, have put back together and it won't boot, I'm certain the mother/daughter board is getting power and it's a new screen, just doesn't seem to want to power on or even say it is charging, any help would be greatly appreciated!
https://linustechtips.com/topic/1631087-rog-phone-help/
40 minutes ago, Acertone said:
Hi there,
IMO, bring it to a phone repair shop
Refresh before you reply
https://linustechtips.com/topic/1631087-rog-phone-help/#findComment-16858250
1 hour ago, Acertone said:
Hi there,
does it vibrate when you keep pressing the power on? did you put your phone in charge? sometimes the batteries that you receive are not charged up, i usually leave 2 to 3 hours the phone in charge after i've swapped the battery with a new one
                   -`                    y0ur5h4d0w@Darkness
                  .o+`                   -------------------
                 `ooo/                   OS: Arch Linux x86_64
                `+oooo:                  Host: Darkness
               `+oooooo:                 Kernel: Latest
               -+oooooo+:                Packages: Only what i need to keep it simple
             `/:-:++oooo+:               Shell: ZSH
            `/++++/+++++++:              Main Monitor: LG Ultragear LG 27GS85Q
           `/++++++++++++++:             Secondary Monitor: Asus MG28UQ
          `/+++ooooooooooooo/`           DE: Plasma Always Bleeding Edge
         ./ooosssso++osssssso+`          WM: kwin
        .oossssso-````/ossssss+`         Theme: Breeze-Dark [GTK2], Breeze [GTK3]
       -osssssso.      :ssssssso.        Icons: Breeze-dark [GTK2/3]
      :osssssss/        osssso+++.       Terminal: Kitty
     /ossssssss/        +ssssooo/-       Terminal Font: Noto Color Emoji 17 FreeMono 13
   `/ossssso+/:-        -:/+osssso+-     CPU: AMD Ryzen 7 9800X3D (16) @ 5.307GHz
  `+sso+:-`                 `.-/+oso:    GPU: AMD ATI Radeon RX 7800 XT
 `++:.                           `-/+/   GPU: AMD ATI Radeon Graphics
 .`                                 `/   Memory: 61830MiB
https://linustechtips.com/topic/1631087-rog-phone-help/#findComment-16858259
No Vibrations at all, could feel the batteries warm up a bit on charge, so they are charging for sure.
it shows no responsiveness when pressing or holding the power button at all.
https://linustechtips.com/topic/1631087-rog-phone-help/#findComment-16858282
keep the phone in charge for some hours, if the screen works it should display an indication that the battery is charging or is fully charged
of course, ALWAYS KEEP AN EYE ON THE PHONE because if the charging board of the phone is damaged it will get pretty toasty and it might not turn out in a very nice situation
https://linustechtips.com/topic/1631087-rog-phone-help/#findComment-16858286
