So silly, sound issues...
13 hours ago, Cramig88 said:hmm, too much electric out these sockets could cause interference, that is a very valid point.
directly below me, well almost, its on a different breaker, is my 7.2 surround blah blah home theature. that has no problems, except when i hook up the pc. i have a hdmi to rj45 balun, that has its own quirks but the audio problem remains the same. anything pc related (from this watercooled thing), causes problems just with audio.
ive removed any audio "enhancements", whatever, disabled them completely. i have my ps5 controller via ds4win, headphone jack at whateverKhZ (it only supports one).
EMI is a very possible cause, between the pc, waterblocks, radiators, and a boatload of power whips, eh.
but even so, if i use sunshine/moonlight, i shouldnt have crackling in the home theature area. i dont have that issue with plex/SmartTube and so on.
cant say if its isolated in the office or not, but it seems to be.
the grounding could very well be an issue, theres a lot of plugs herethats been persistant
yea it could be that circuit a ground might be wired wrong or disconnected. it could be at the breaker box, in a plug outlet or a junction box, could be a broken wire somewhere in the wall or attic.
get you something like this
https://www.homedepot.com/p/Power-Gear-3-Wire-Receptacle-Tester-50542/206212329
this at least you can check on grounds and see where theres issues. after that can be a pain tracing the issue down
