Hi,
I have a Seasonic PRIME PX-1600. I lost the AC power cord and the 3 pins design is not the same type as all my other psu power cables. The connector looks like Amazon.com: StarTech.com 10ft (3m) Heavy Duty Power Cord, NEMA 5-15P to C19 AC Power Cord, 15A 125V, 14AWG, Computer Power Cord, Heavy Gauge Power Cable for PDUs and Network Equipment, UL Listed (PXT515191410) : Electronics
I am worried as not being direct from the manufacturer that it may damage the PSU or other components.
Thank :)
https://linustechtips.com/topic/1629222-lost-ac-power-cable/
5 minutes ago, Fugaroo said:
Hi,
Thank 🙂
Should work.
IIRC past 1000w PSUs uses C19 instead of C13
As long it's well enough made it wont damage your stuffs.
Refresh before you reply
https://linustechtips.com/topic/1629222-lost-ac-power-cable/#findComment-16844716
28 minutes ago, Bitter said:
Why not just email Seasonic about a replacement cord?
They probably ask for your grandma's birth certificate and microcenter CCTV footage to prove you actually exist and bought the PSU, it's easier to get a new one.
39 minutes ago, Fugaroo said:
It got pretty good reviews. Hope that means it's good.
Shady sellers can buy Indian reviews for like 1000/$2.50, but it should be fine if it's a cable. Make sure both ends fit right and don't wiggle around.
DIn4L7hUmUI
https://linustechtips.com/topic/1629222-lost-ac-power-cable/#findComment-16845299
I mean he can probably buy one from them.
https://seasonic.com/contact-us/
Can't hurt to ask. At least he'll know he has the real deal cable instead of wondering/worrying.
https://linustechtips.com/topic/1629222-lost-ac-power-cable/#findComment-16845312
