Hello guys, i recently bought thr rx 9070xt. For cpu i have the ryzen 5 5600x, i know i would have bottleneck and i was saving up to upgrading to AM5. Although fate had other plans and ram and ssd prices skyrocketed. I wanna do an upgrade to my pc and i am thinking to get a better am4 cpu. Tell me your opinions.
https://linustechtips.com/topic/1627825-cpu-problem/
The only worthy upgrade is a 5700X3D or 5800X3D.
For 1440p, the 5600x is actually plenty good enough with a 9070 XT:
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834644
Honestly, unless you can find a used 5700X3D or 5800X3D for a reasonable price (like under $300 USD), I would just stick with the 5600X. It's not like your PC is going to blow up if you are CPU-limited.
If you have a CPU bottleneck and can't maintain a consistent frame rate, using a frame capper like that found in RTSS and capping to a frame rate you can mostly hit consistently will usually help make the game feel better. When you're CPU-limited, a capped consistent frame rate is often more pleasant than a frame rate with a higher average but big frame time swings.
If you then find yourself with a ton of extra GPU headroom because of the capped frame rate, you can increase image quality using Virtual Super Resolution to get more out of your GPU.
"TV Gaming" PC: Ryzen 5 5600 :: 32GB DDR4-3200 :: RTX 2070 Super :: 500GB PCIe 3.0 SSD :: 1.5TB of SATA SSDs :: Windows 11
"Desk Gaming" PC: i5-4690K :: 16GB DDR3-1600 :: RX 560D 4GB :: 500GB SATA SSD :: Linux Mint 22
Office PC: Dell Pro 14 :: Ultra 7 268V :: 32GB DDR5-8533 :: 512GB PCIe 4.0 NVMe :: 6TB HDD :: Windows 11
Laptop: Dell Latitude 15.6" :: i5-4200U :: 8GB DDR3-1600 :: 500GB SATA SSD :: Linux Mint 22
Primary NAS: i5-7500 :: 16GB DDR4-2133 :: 250GB SSD :: 8TB HDD :: TrueNAS Scale 24.10
Web Server/Backup NAS: Raspberry Pi 4 Model B :: 2GB RAM :: 64GB microSD card :: 8TB HDD :: Raspberry Pi OS
Other tech stuff: iPad Pro M4 13" :: Samsung Galaxy A15 4GB :: 2022 Kindle Fire HD 7 :: PS4 Slim w/ 1TB SSD :: OG Nintendo Switch
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834647
what is Virtual Super Resolution
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834664
The 5600X is a pretty reasonable pairing for the 9070 XT, I would not be too concerned about bottlenecks unless you are having a specific performance problem in a game you play often.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834666
for example i paly bf6 and my gpu can go up to 240 fps in low settings in 1080p and my cpu is at 110 fps
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834669
8 minutes ago, panukla said:
if i get the non 3d versions ? because in greece is hard to find them and expensive
Imo not as worth it.
And ik their prices, they can be found for 200-250 euros
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834670
What speed of ram are you currently using?
As the others have mentioned, the only practical upgrade for you would probably be the X3D processors. If you go with the 5700X, or something similar, you would have more cores but it would not result in a very large performance boost. From the benchmarks I have seen, the 5700X performance is similar to 5600X in battlefield 6
Primary PC:
PSU tier list
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834672
2 x 8 gb ddr4 3000mhz
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834674
You would benefit from faster ram. Ryzen CPUs depend on ram speed for core-to-core communication. If you get some DDR4 3600, that would improve your CPU performance a little.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834676
9 minutes ago, panukla said:
in what sites
Eshop.gr and skroutz.gr.
Tho you need to wait for them to return to stock cause sales and they have fake scarcity.
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834679
41 minutes ago, panukla said:
yeah but they are expensive
more expensive than a new CPU?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834691
It's a setting that allows you to run the game at a resolution that's higher than your monitor's resolution, and then downsample to your output res. This will improve image quality - basically it's really effective anti-aliasing.
It's kind of the opposite of upscaling (DLSS/FSR).
And 110 fps is still great performance! Just use VSR to crank the res scale, turn off the frame counter, and enjoy the game.
You're already having a perfectly good gaming experience. Don't let FOMO make you spend a bunch of money on inflated-price hardware when the actual subjective difference it makes won't be that significant.
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834707
so should i get a new 1440p monitor
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834708
If you're still playing at 1080p and you're really itching to upgrade something, yes, I'd probably upgrade the monitor
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834709
do you have any recommendation or a link for monitor. i am looking to spend top 250 euros
Honestly no, it's been ages since I paid any attention to the monitor market. I'd just go search "1440p monitors" on rtings and try to find one that's available in your price range and has good ratings on that website.
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834711
alright thanks for your help
https://linustechtips.com/topic/1627825-cpu-problem/#findComment-16834713
