Some motherboards have a special AIO header, but if yours doesn't then yes you can use the CPU_FAN header to power the pump.
You will, however, need to set the fan curve of this header appropriately. Read the manual for your AIO and follow what it says. Some pumps don't like receiving PWM signals and you might need to set the header to 100% always.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
