gpu clock always at max
Solved by Hinjima,
6 minutes ago, karmic tr said:my gpu clock speed is alaways at max and so is the memory idk if its normal i though it would lower it self when not in use i also have a secondary gpu igpu that should be in use when not using 3d applications
I see that you have an Nvidia GPU.
Can you check your power settings in the Nvidia Control Panel?
If its set to maximum performance the GPU clock will always be at max.
