I recently bought a B580, and installed it in my PC, however, it would not boot, after some troubleshooting, and switching to a CPU with an iGPU just to get into BIOS/Windows to see what was going on, I got the following error messages, and even artifacts after trying to install the drivers. Any thoughts as to what could be causing this?
https://linustechtips.com/topic/1625547-problems-with-the-b580/
A faulty card.
Still, have to do the normal troubleshooting steps starting with DDU.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1625547-problems-with-the-b580/#findComment-16818558
1 hour ago, JonyVole said:
yeah i tried DDU, the card was broken all the same, guessing i have to return it?
There is of course fully reinstalling Windows, reseating the card, trying a different slot (for troubleshooting purposes), trying the card in another PC, CMOS resets, BIOS updates.. these are all more involved so it'll be up to you how much you're willing to do.
https://linustechtips.com/topic/1625547-problems-with-the-b580/#findComment-16818664
well, i have the latest BIOS, reset the cmos, reseated, windows reset is off the table tho, was hoping there was something about intel cards i didnt know, the more i read the more it sounds like a bad part
https://linustechtips.com/topic/1625547-problems-with-the-b580/#findComment-16818673
Nothing thats just going to prevent the card from functioning normally on a basic level. Even with ReBAR off nothing like that should be happening.
https://linustechtips.com/topic/1625547-problems-with-the-b580/#findComment-16818676
