Split second white line on display
Solved by podkall,
12 hours ago, koopa990 said:Wait... WAIT. The very rare flickering, split second white line is back again... I guess its the display itself huh?
Could be, or GPU.
Do you ever use PC without gaming at all, or do you almost always run some game when the PC is on? Because that could rule out GPU potentially.
More arrows point to the display though, since straight line artifacts are common on failing displays or when parts of display fail:
Supposedly you don't have second monitor?
