SSD speed troubleshooting
4 hours ago, Sawa Takahashi said:It shouldn't happen but sometimes you need to reinstall Windows from scratch instead of cloning a boot drive. There may be some leftover driver bits that conflict with the new hardware and Windows being Windows....
As for the speed, even a WD blue is faster than the interface itself for reads and short bursts of writes. If you are writing large amount of data, you may experience some slowdowns due to the write buffer being full, but that happens with all SSDs.
Hope that helps !
Make sure the new SSD is running in AHCI mode in BIOS, not IDE.
Check with CrystalDiskInfo or similar if the drive is healthy and on the right SATA speed should be SATA III 6Gbps.
Sometimes a bad clone causes Windows to keep indexing or doing background tasks, that can peg disk usage at 100%. A clean Windows install on the new SSD can rule this out.
Also check that you’re on the latest chipset/storage drivers for your motherboard.
