I would am making a little emulation box out of an "old" laptop MSI GE60 and on the board and I would like to find some extension cables for the connectors on the pictures, I know they exist but I cant find any easy way to buy them. I live en Denmark. Im pretty sure its a 60 pin and a 90 pin.
Maybe its called Extension Cable FPC Male and Female BTB Cable, im not sure PLease help.
https://www.alibaba.com/product-detail/24-30-40-60PIN-Camera-Cable_1601243062853.html?spm=a2700.prosearch.normal_offer.d_image.2bd967afA2DI5J&priceId=0f07487db8014e9395f4fbb2f3905ce2
https://linustechtips.com/topic/1622222-laptop-emulation-btb-cable-problem/
What you’re looking for are FPC/FFC extension cables sometimes called BTB extension. They come in different pitches like 0.5 mm or 1 mm and pin counts, so you’ll need to measure your connector and confirm if it’s 60-pin and 90-pin as you suspect.
Places like AliExpress, Mouser, or Digikey usually have them listed as ‘FPC extension cable male-to-female’. On AliExpress/Alibaba you can also search ‘FPC/FFC extender 60-pin’ and filter by length and pitch.
Important:
Check the pitch distance between pins. Common ones are 0.5 mm and 1 mm.
Match the orientation same-side vs opposite-side contacts.
Length can affect signal quality, so don’t go too long if it’s for high-speed data.
So yes, FPC male/female BTB extension’ is the right search term, just double check the pitch with calipers to avoid buying the wrong type.
