CPU overheating
Go to solution Solved by Dedayog,
42 minutes ago, One Angry Soldier said:
What type of thermal paste is he using? I had a similar problem with mine and discovered that the thermal paste was not the right kind for the cooler. I was using basic thermal paste, for an AIO cooler. I later switched to Kingpin Cooling KPx, and have never looked back. I know that the cooler is a basic, and not an AIO, so you want to make sure that the CPU is fully covered. Most coolers come with thermal paste pre-installed but some of them won't give full coverage on the CPU. The old way used to be doing a pea-sized drop, but now they say it's better to use a thermal paste spatula to spread it, to ensure proper coverage.
How does thermal paste differ from an aircooler to an AIO?
I can see if it's on a GPU maybe, runout being an issue, but the coldplates are basically the same, the mounting is the same, etc
39 minutes ago, OxikCZ_ said:
Honestly i have no idea, could be worth looking into it. I called him and it was pre applied on the cooler.
I'd say the cooler wasn't mounted well.  When he puts new paste on, literally any since it's just a 3600, then make sure to properly mount the cooler.
Pre-applied paste is fine.  I use it on anything it comes on.  If I am needing paste, I use ThermalGrizzly Kyronaut.  Otherwise preapplied all day.
https://linustechtips.com/topic/1621425-cpu-overheating/#findComment-16790233
Edited by OxikCZ_
https://linustechtips.com/topic/1621425-cpu-overheating/#findComment-16790237
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1621425-cpu-overheating/#findComment-16790249
23 minutes ago, OxikCZ_ said:
My friend has a pc with ryzen 5 3600 he has the Arctic freezer 7x "cooling" it but the temps are soo high like 50-60 on desktop and around 90-96 when playing. I was wondering if anybody had same experience with this cooler or if anybody has any ideas on how to fix it.
Cooler isn't good, badly installed, or fan too slow
Maybe reinstall/repaste it, check fan speeds, or just get a better one (TR PA120 is 30 bucks)
https://linustechtips.com/topic/1621425-cpu-overheating/#findComment-16790250
Definitely look into it. It's quite possible that it wasn't covering the whole CPU, which could cause overheating issues over time. He should remove the cooler and use an alcohol pad, to completely clean off the paste from the cooler and CPU, then make sure it's completely dry (paper towel works), and try applying some Kryonaut Thermal Grizzly paste (if he doesn't mind the extra expense), or something like that. Like I said, they make different paste for different types of coolers. There are some that are great for fan coolers, but not recommended for AIO and block coolers.
https://linustechtips.com/topic/1621425-cpu-overheating/#findComment-16790252
You might be correct. I'm still pretty new to this. I was doing some research about different thermal paste, since I was upgrading my system, and there was a statement somewhere saying that not all thermal paste is equal. They make some that's better for fan stock coolers, and others that are better for AIOs. They say that you can use thermal paste recommended for aios on stock coolers, but not the other way around. I can't remember which website I read that on. I think it was PC build, or something like that. Anyway, I know that this will probably be blasphemous, but I went with Jayz recommendation of Kingpin, because it doesn't dry out, or crack, and maintains that proper thermal regulation, for a lot of years. He said that some of the other pastes are really good, but can dry and crack over time, rendering it useless.
https://linustechtips.com/topic/1621425-cpu-overheating/#findComment-16790257
