i got a projector for my tech room and i got for 40.00 an it has vga i use a hdmi to rca it sucks an i have a pc i was using as a media pc i bought a dell omiplex used one an i upgraded it cpu from an i3 to a xeon an i need it vga an i had a radion card as it video out put is there a way to use the gpu for the motherboard video out put is there a bios setting for that ?
https://linustechtips.com/topic/1620875-need-help-on-something/
No, you can't pass video from the dedicated GPU through the motherboard, especially not without integrated graphics. (Assuming your Optiplex will POST with a Xeon in the first place; that could be artificial market segmentation to make a niche for the low end Precision workstations.)
All you need is an active HDMI to VGA adapter like this, plus a VGA cable:
https://www.amazon.com/Moread-Gold-Plated-Projector-Chromebook-Raspberry/dp/B00SW9JI9A/
1 hour ago, esCaPade1 said:
For the video connection on a motherboard to work, the CPU installed must have an on-board GPU. Xeon processors do not have those (or very few - only old E models).
So no, basically.
The E3 Xeons with model numbers that end in 5 generally have integrated graphics. (But there's no reason to pick those over a regular i5 or i7 unless they're far less expensive, or you absolutely need support for unregistered ECC memory. They can't handle the cheap registered ECC that comes out of servers; for that you need a full-fat server socket like LGA2011.) The best way to know for sure is to look up the spec list on Intel's support site.
https://linustechtips.com/topic/1620875-need-help-on-something/#findComment-16786779
