First ever build- need suggestions
Go to solution Solved by Why_Me,
https://www.asrock.com/Power-Supply/SteelLegend/SL-750G/
https://www.cybenetics.com/evaluations/psus/2669/
PCPartPicker Part List
Power Supply: *ASRock Steel Legend SL-750G 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Newegg)
Total: $89.99
Generated by PCPartPicker 2025-08-17 21:03 EDT-0400
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  ($29.99 @ Amazon)
Total: $29.99
Generated by PCPartPicker 2025-08-17 21:00 EDT-0400
CPU Cooler: *Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Total: $35.90
Generated by PCPartPicker 2025-08-17 21:01 EDT-0400
CPU Cooler: *be quiet! Pure Rock Pro 3 59.6 CFM CPU Cooler  ($49.90 @ Amazon)
Total: $49.90
Generated by PCPartPicker 2025-08-17 21:02 EDT-0400
Budget (including currency): $1000-1200
Country: USA
Games, programs or workloads that it will be used for: Other details  Python, ML/AI learning, some general development. Not focused on gaming.
Here’s my current PCPartPicker list (~$1450):
https://pcpartpicker.com/list/yrs9mC
CPU: Ryzen 9 7900X
Cooler: Noctua NH-D15S
Motherboard: MSI PRO B650-S WiFi
Memory: TeamGroup T-Create Expert 32GB DDR5-6000 CL30
Storage: Crucial P3 Plus 1TB NVMe Gen4
GPU: MSI RTX 5070 12GB
Case: Montech X3 Mesh
PSU: Cooler Master MWE Gold 750W
Looking for advice on:
Whether this config is overkill for my use case.
Any cheaper but reliable alternatives (especially cooler, PSU, or storage) to bring it closer to my budget.
Any red flags in terms of compatibility or value.
Thanks in advance!
https://linustechtips.com/topic/1620589-first-ever-build-need-suggestions/
Country: USA
CPU: Ryzen 9 7900X
Thanks in advance!
You can definitely save a bit on the cooler by going with a Peerless Assassin SE120, Noctua's are incredibly over priced.
Maybe you could pick up a used RTX 4070 Super or something as well?
Will the extra tensor cores in the 5070 be useful to you in AI learning?
Total: $89.99
Total: $29.99
Total: $35.90
Total: $49.90
