Need help with psu
Go to solution Solved by Hinjima,
4 minutes ago, cardVal said:
Hi
My gpu(1660s) died recently after a good 6 years(RIP) and my friend offered to sell me his old 5700xt at a lowered price. My psus connectors wont work with it so ive been looking for a new one to buy. I have a 7500F and will soon have the rx5700xt.
Any ideas? im looking at the A650BN cause ive heard its okay for my budget
Thanks
We actually recommend the MSI ABN Series of PSU's multiple times a week for budget builds.
It will handle a 7500f and 5700 XT without any problems 🙂  Its an okay PSU on a budget.
Hi
Thanks
https://linustechtips.com/topic/1620356-need-help-with-psu/
Hi
Thanks
https://linustechtips.com/topic/1620356-need-help-with-psu/#findComment-16783280
3 hours ago, Tan3l6 said:
But in PCPartpicker MSI MAG A750BN PCIE5 is just few bucks more than A650BN. Perhaps better value?
https://pcpartpicker.com/product/bpvD4D/msi-mag-a750bn-pcie5-750-w-80-bronze-certified-atx-power-supply-mag-a750bn-pcie5
Not really. You can get a better PSU for the same price https://pcpartpicker.com/product/mBgrxr/asrock-challenger-cl-750g-750-w-80-gold-certified-atx-power-supply-cl-750g
https://linustechtips.com/topic/1620356-need-help-with-psu/#findComment-16783413
3 minutes ago, --SID-- said:
I would not approach any ASrock component with a 10 foot pole, but it seems to be rated higher indeed (B with an asterisk):
https://docs.google.com/spreadsheets/d/1akCHL7Vhzk_EhrpIGkz8zTEvYfLDcaSpZRB6Xt6JWkc/edit?gid=931697732#gid=931697732
Pax vobiscum
https://linustechtips.com/topic/1620356-need-help-with-psu/#findComment-16783415
