Budget (including currency): £450 -£500
Country: UK
Games, programs or workloads that it will be used for: media, streaming, light video server for cameras
A rough idea - https://uk.pcpartpicker.com/list/myZbYd
it need to fit in a media cabinet (its quite large)
Ideally like atx power supply (budget)
https://linustechtips.com/topic/1618681-help-with-media-pc/
Country: UK
i made a few changes, https://uk.pcpartpicker.com/list/HNmMHW the power supply i put in is a but overkill for the wattage but it will give you a large upgrade path
https://linustechtips.com/topic/1618681-help-with-media-pc/#findComment-16772804
upgrade path for what? 😅
also quite loud and expensive given the options
1 hour ago, Cloggy987 said:
Does it need wifi capability?
Quite pricey NVME for the use-case and also cheaper alternatives.
https://uk.pcpartpicker.com/list/bfw4TM
current PC:
PC configs I used before:
https://linustechtips.com/topic/1618681-help-with-media-pc/#findComment-16772826
it may one day need a gpu, and it will be one less thing for them to upgrade when eventually like all pc's  it becomes outdated for what they need it for
https://linustechtips.com/topic/1618681-help-with-media-pc/#findComment-16772844
looks good the mobo looks better does the 5600gt need a third party cooler ?
https://linustechtips.com/topic/1618681-help-with-media-pc/#findComment-16773074
yes it wifi would be nice.
(SSD) it was on sale
would you recommend a third party cooler (its not going to be used much for single core loads often
https://linustechtips.com/topic/1618681-help-with-media-pc/#findComment-16773075
it doesn't need it, you can start with the stock cooler and if temps are too high you could get a third party cooler
https://linustechtips.com/topic/1618681-help-with-media-pc/#findComment-16773088
doesn't need it very much, the stock cooler can keep 6 core AM4 CPU in acceptable temps even if all cores are used
current PC:
https://linustechtips.com/topic/1618681-help-with-media-pc/#findComment-16773168
