RGB Help
33 minutes ago, james8449834 said:So I didn't really care about RGB when ordered this so not of a mix and match of components from different companies.
I downloaded signal and it's talking to my ram sticks and case fans but it not picking up my graphics card.
I suspect it's not supported. It's an asrock steel legend rx9070xt.
Is there an other that will control all of them.
Gigerbit B850 motherboard controling the case fans and Corsair ram sticks.
Failing that can anyone suggest any free signal profiles that compliment the selection that's available on asrock polychrome sync
Since the card is still fairly new, chances are they (SignalRGB) are still working on it.
Maybe try their BETA release.
Or hop into their discord channel and ask if there are workaround
