I would honestly refrain from using a wireless adapter in a desktop. If there is a possibility of running a cable from your router to your system, do it.
If not, Is there a budget you are on?
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
No budget really looking for ideas
Then I'd go with this: http://www.asus.com/Networking/PCEAC68/
Pretty much the best you can get. It retails for around £65, not sure what it's priced at in your country, but it has wireless n as well as ac, so it should last a fair bit.
If I run a cat 5 cable would the network port on the motherboard work fine I have a Asus m5a97
Yup, it should be fine. The spec says the mobo has a gigabit connector, so you should have no problems whatsoever.
