Question regarding UPS Battery backup
You should be good with that UPS as long as you change the batteries every 5 years or so. This is normal wear from the batteries.
If you want to test the absolute max power used by your computer, you can simply run Furmark and Prime95 at the same time. Please be aware that this will turn your computer into a toaster and do not let it run like that for more than a couple of minutes.
As for buying a more powerful UPS 'just in case' you'd be surprised how to next model costs. 1500VA is the most powerful personal use affordable UPSes. For comparison, Eaton, Cyberpower and Tripp-Lite sell their 2000VA UPS at around $2000. This is a big jump from the 1500VA you bought.
In my opinion, you should go with the UPS you bought. This is a powerful model, easy to use and configure and the replacement batteries are standard batteries you can buy from third parties.
Have a nice day !
