Low gpu utilization
Solved by Eigenvektor,
57 minutes ago, Justbon321 said:Youre right i might just need to upgrade my CPU, cause i aint tryna turn my grapphics up literally turned them down to get more fps
Yeah, if your GPU is at 30–40% utilization, something else is the limit. Typically the CPU, though the CPU in turn could also be limited by RAM performance. In that case turning up graphics would simply increase the work for the GPU without reducing frame rate.
The higher the frame rate, the more often the CPU has to send data to the GPU to work on. If it isn't fast enough to run the game's simulation and do that at the same time, lower GPU utilization is the result.
