Double checking my first build
4 minutes ago, Sip said:
Warning: The Asus Motherboard supports
This should be fine. Most of the mobos you'll be able to buy will have had the updated BIOS flashed at the factory.
Still, not a bad idea to update it to latest release when you get it.
6 minutes ago, Sip said:The second one I'm having a hard time visualizing and checking
This shouldn't be an issue as long as you don't plan to have hard drives
6 minutes ago, Sip said:. I can wait a year if that means the price of the components would drop. My question is if they will or not? Is there a possibility that they can get higher?
The rule of thumb in tech is that prices go down over time. This has largely been true with the exception of GPUs which have been all over the place for the past 5 years.
The answer to "should I wait" is usually answered with "do you want/need a new PC right now?" If you have a rig you're happy with now, wait. There will potentially be a new generation of CPU in a year or so. If you don't have one, or it's feeling creaky and in need of an upgrade, get one now.
9 minutes ago, Sip said:Finally, if anyone with experience sees something weird about my build, has any recommendations or improvements to suggest, I'm more than happy to hear them!
Honestly a very nice rig all together. The 4TB SSD is huge, but not a problem. I usually spec 2TB drives. Great choice of RAM and solid PSU. I'd say it's mint!
