PC building hiccup
Go to solution Solved by Translucent_Fire,
2 minutes ago, Translucent_Fire said:
Some times they can take a minute. I am looking to see if anyone has any news on your board.
CHEESE & RICE!
Motherboard: B650 Eagle AX
CPU: Ryzen 5 7600x
Cooler: Thermaltake Aqua Elite
RAM: Corsair Vengance DDR5-6400 32GB(2×16GB)
I have some (VERY minimal) experience building PCs, and i took on a build project for a family friend. Finally got everything together and turned it on for the first time, and im seeing several issues:
My motherboard's error lights are coming on, and the fans aren't spinning on/lighting up.
I suspect the fan hub isn't plugged in, but i won't have a chance to properly check until later tonight.
As for the MB lights, the CPU light comes on for about 1 second before THE DRAM light comes on and stays on. I've tried reseating the CPU and the cooler, as well as swapping/testing the RAM sticks.
Thankfully the build isn't on a heavy time constraint, but im looking for any help I can get to try and fix this.
https://linustechtips.com/topic/1614330-pc-building-hiccup/
CPU: Ryzen 5 7600x
do you have different ram you can test with?
https://linustechtips.com/topic/1614330-pc-building-hiccup/#findComment-16743698
3 minutes ago, Translucent_Fire said:
I know this sounds silly but did you check to make sure you had the RAM in slots A2 & B2?
Could just be bad if they are in the right slots.
I won't be able to check until later tonight, but i previously tried individually testing each stick in all 4 slots and nothing worked
https://linustechtips.com/topic/1614330-pc-building-hiccup/#findComment-16743724
Check which memory slots you are using.
Gigabyte as a little indicator silk-screened onto the motherboard to use these slots first.
Do you have EXPO / DOCP enabled?
What happens if you disable EXPO / DOCP?
DDR5-6400+ is still uncommon to reach on Ryzen 7000/9000-series, without brute forcing it.
I learned that myself recently trying to run EXPO DDR5-6400 CL30 on my 9800X3D.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1614330-pc-building-hiccup/#findComment-16743725
That is a great test to try. How long did you wait for boot? Some BIOS are a straight pain to boot up and can take a hot minute too boot. I have a (which I have to update here) a Ryzen 5 8500G X870 64GB and when I change my RAM speeds it takes 1.20 minutes to except the new change.
https://linustechtips.com/topic/1614330-pc-building-hiccup/#findComment-16743728
Did NOT know it'd take that long. I waited ~15 seconds on each RAM slot on each stick
https://linustechtips.com/topic/1614330-pc-building-hiccup/#findComment-16743731
I dont know what EXPO/DOCP is. I haven't been able to boot into bios and dont have an OS installed yet.
https://linustechtips.com/topic/1614330-pc-building-hiccup/#findComment-16743732
