Quick Start Guide - Einstein@home
Einstein@home goal is to use your computers "idle" time to search for weak astrophysical signals from spinning neutron starts. Utilizing data from the LIGO gravitation-wave detectors, MeerKAT radio telescope and fermi gamma-ray satellite. Also using archival data from the Arecibo radio telescope (RIP). This project is able to utilize both CPU and GPU to achieve it's objective.
For the 2026 BOINC Pentathlon Einstein@home is the City run event which is running for 5 days, May 12-17th.
Account Setup
 1) If you have not already, download and install the BOINC manager here: https://boinc.berkeley.edu/download.php or in a Debian/Ubuntu based Linux system run sudo apt install boinc
2)If adding project from the BOINC Manager next click on Tools --> Add Project...
3)Next Scroll to Einstein@Home and hit Next
4) Agree to the terms and conditions and hit Next again, next you'll need to either create an account or if you have an account already login
     don't bother trying the email, it doesn't exist 😛
5) At this point you see it connect to the Einstein@Home server and see the project added to your list like below
At this point I recommend hitting Suspend and No New Tasks if you want to change what type of tasks you wish to work.
6) Now to visit https://einsteinathome.org/ for some configuration, login into the email you provided when creating the account.
7) You'll click on the View Account tab and come to this screen. From there click on Preferences
8) We are now adjusting your preferences to permit exporting your stats to other websites like BAM! by going to
     Preferences --> Privacy --> Clicking Yes on Do you consent to exporting your data to BOINC statistics aggregation websites?:
Now you should be sharing to BAM for Stats/points collection
9) Now to project settings, now click on the Project tab, This is where you can enable/disable your CPU/GPUs and adjust what tasks you'll receive. For example below I am gunning mostly GPU tasks so for the 2026 BOINC Pentathlon I am running the current Resource share and Applications settings
     *I am running a 9070XT and Arc B580 this year so didn't bother with Nvidia or Apple. Pick for your situation
     *If running something like a Raspberry Pi, you'll need to check [BRP4]
After all is set up, MAKE SURE YOU HIT SAVE CHANGES. It's on the bottom, don't be like me.
10)Almost forgot about joinng LinusTechTips_Team!!! Go to the following tabs Community --> Teams
     From there search for LinusTechTips_Team
Now click on the team and Join This Team
10) Alright now you should be all set for using Einstein@Home! Just click on Resume and Allow New Tasks.
ExtremeOC Folding Stats     LARS Systems Folding Stats     BOINC Stats     Free-DC BOINC Stats
Current Rigs
Raspberry Pi 5 8GB, Raspberry Pi 5 2GB,Raspberry Pi CM5 4GB, Raspberry Pi 4 4GB, Raspberry Pi 3, Raspberry Pi Zero W, Raspberry Pi Zero...I like Pi
ArchNorth ~ Fractal North, Noctua D15, ASRock Riptide B550, Ryzen 7 5700X, Sapphire B580 Titan O.C.
Smalls ~ Fractal Terra, ASRock B650I, Noctua NH-L12x77, Ryzen 9700X, Powercolor Reaper 9070XT
Goat ~ Geeek A50, Gigabtye X570, Ryzen 5500, Intel B580 FE
Beater Lenovo IdeaPad U430 Touch laptop that wont die
https://linustechtips.com/topic/1611766-quick-start-guide-einstein/
Registering for an account doesn't not seem to work if you do it through the BOINC Manager. I had to go to https://einsteinathome.org/user/registration to create one.
In pursuit of knowledge and mistakes.
Please quote or @ me if you want me to be notified. Mark replies as answers if they solved your problem.
Folding at Home BOINC
