Budget: 2000lv (1000euro)
Country:bulgaria
Games, programs or workloads that it will be used for: the last of us,rdr,fortnite,cs2
Hello, i have been thinking of building a pc after this summer and i need your help with picking parts. Now dont come at me but im planning on playing at 1080p since im at a budget but if you have any ideas for a budget 1440p build im all ears. Also the budget up above is for without monitor. I want my pc to have atleast 1tb ssd since im more into story games and also 32gb ram wont be bad. Ive been searching for parts everywhere but im not the best at this so im trying to get some advice. Since ill mostly play games like tlou i think i might need a gpu with more than 8gb vram. My main point is to enjoy gaming no matter the resolution since ive been playing on 1080p all my life so i wont really see much of a difference. Right now im using a really weak laptop so i cant change parts. My main goal is to play at high settings with minimum 60/70fps. Thank you for your time and advice. Also i forgot to mention that ill need a wifi motherboard or some good wifi card.
https://linustechtips.com/topic/1609702-building-pc/
It might be worth waiting for the 9600 XT. The 5060 Ti 16GB has released already and is I'm afraid, not cheap.
Other cards you could consider:
Arc B580 (12GB)
7700 XT (12GB)
3060 (12GB)
https://linustechtips.com/topic/1609702-building-pc/#findComment-16711367
I'm with Tetras, all good card, I personally used a 3060 when I was on a budget. You can pull off 1440p on most of those games with a 3060, just don't go cranking all your settings to high.
If you really want to save some money, used is a good option, looks like 3060 are going for around 250ish here in the US on ebay, could probably snag a 3060ti or 3070 for 300ish if you do some hunting and digging and negotiating.
Turning it off and on actually does help. Sincerely, I.T. Specialist.
https://linustechtips.com/topic/1609702-building-pc/#findComment-16711387
Country:bulgaria
1080P
https://www.vario.bg/asrock-a620m-pro-rs-wifi-90-mxblx0-a0uayz
ASROCK A620M PRO RS WIFI 247.00ЛВ
https://www.vario.bg/amd-ryzen-5-7500f-100-100000597mpk
AMD RYZEN 5 7500F 294.00ЛВ
https://www.vario.bg/thermalright-peerless-assassin-120-se
THERMALRIGHT PEERLESS ASSASSIN 120 SE 69.00ЛВ
https://www.vario.bg/teamgroup-t-create-expert-black-dimm-kit-32gb-ctced532g6000hc30dc01
TEAMGROUP T-Create Expert DDR5-6000 32GB (2x16GB) CL30 201.00ЛВ
https://www.vario.bg/gigabyte-ssd-1tb-gp-gstfs31100tntd
GIGABYTE 1TB 2.5" SATA SSD 108.00ЛВ
https://www.vario.bg/palit-geforce-rtx-4060-infinity-2-ne64060019p1-1070l
PALIT GEFORCE RTX 4060 INFINITY 2 8GB 607.00ЛВ
https://www.vario.bg/msi-mag-a650bn-650w
MSI MAG A650BN 650W 131.00ЛВ
https://www.vario.bg/deepcool-cc560-mesh-v-r-cc560-bkama4-g-2
DEEPCOOL CC560 MESH 108.00ЛВ
Total: 1765ЛВ / €902,44
https://www.tomshardware.com/software/windows/windows-11-free-or-cheap
https://www.vario.bg/gigabyte-g24f-2
GIGABYTE G24F 2 301.00ЛВ
https://www.gigabyte.com/Monitor/G24F-2#kf
https://linustechtips.com/topic/1609702-building-pc/#findComment-16711415
10 hours ago, Why_Me said:
1080P
wont it be better to use 7600x
and also is the 4060 good too? I think my biggest problem with this card is that its 8gb vram and the 16gb one is 1050lv which is 525 euro
https://linustechtips.com/topic/1609702-building-pc/#findComment-16711608
If you can fit the 16GB card into your budget then I would get it.
https://www.techspot.com/review/2728-ryzen-7500f-vs-core-13400f/
https://www.eurogamer.net/digitalfoundry-2023-amd-ryzen-5-7500f-review
https://linustechtips.com/topic/1609702-building-pc/#findComment-16711609
7 minutes ago, Why_Me said:
will the ryzen 5 5600x be good flr the 4060 16gb? or xan i get a better card for that money
https://linustechtips.com/topic/1609702-building-pc/#findComment-16711612
https://www.vario.bg/msi-pro-b760-p-wifi-ddr4-7d98-001r
MSI B760 GAMING PLUS WIFI 312.00ЛВ
https://www.vario.bg/intel-core-i5-12400f-6c-12t-2-50-4-40ghz-boxed-bx8071512400f
INTEL CORE I5-12400F 225.00ЛВ
https://www.vario.bg/endorfy-spartan-5-ey3a001
ENDORFY SPARTAN 5 38.00ЛВ
https://www.vario.bg/gskill-ripjaws-v-dimm-kit-32gb-f4-3200c16d-32gvk
G.SKILL RIPJAWS V DDR4-3200 32GB (2x16GB) CL16 101.00ЛВ
or ....
https://www.vario.bg/asus-tuf-gaming-b550-plus-wifi-ii-90mb19u0-m0eay0
ASUS TUF GAMING B550-PLUS WIFI II 289.00ЛВ
https://www.vario.bg/amd-ryzen-5-5600-tray-100-000000927
AMD RYZEN 5 5600 182.00ЛВ
https://linustechtips.com/topic/1609702-building-pc/#findComment-16711622
8 minutes ago, jasi said:
isnt thus with the 3090? also which one is the best and which gpu is the best combo about the other stuff ive already picked them
Personally I would get that Intel build I posted + 2TB SSD + RX 9600 XT 16GB + 1080P 180Hz IPS monitor
https://linustechtips.com/topic/1609702-building-pc/#findComment-16711633
wont the 9600xt be too expensive for my budget tho
https://www.vario.bg/adata-legend-800-2tb-aleg-800-2000gcs
ADATA LEGEND 800 2TB M.2 PCIe 4.0 NVMe SSD 209.00ЛВ
Total: 1124.00ЛВ
https://linustechtips.com/topic/1609702-building-pc/#findComment-16711642
Total: 1124.00ЛВ
and what gpu?
https://linustechtips.com/topic/1609702-building-pc/#findComment-16711644
2 minutes ago, jasi said:
and what gpu?
thats the buils ive picked for now
cpu:ryzen 5 5600x
gpu:MSI GeForce RTX 3060 VENTUS 2X OC, 12GB GDDR6, 192-bit
cpu cooler: deepcool ak400 digital
ssd:Solid State Drive (SSD) Kingston NV2 2TB, PCIe 4.0 NVMe, M.2
ram: RAM Team Group Vulcan Z, TLZGD432G3600HC18JDC01, DDR4, 32GB 2X16GB, 3600MHz, CL18
motherboard: ASUS PRIME B550M-A WI-FI II Socket AM4
psu:CORSAIR CX Series, CX650, 650 Watt, 80 PLUS Bronze, EAN: 0840006670896 CP-9020278
case: Deepcool CG530 4F, Черен, Middle Tower
fans for the case: ARCTIC P12 PWM PST A-RGB 0dB, 120 мм, Kit
monitor:AOC, 27", IPS, FHD, 180Hz, 1ms, 0.5ms, HDR10, FlickerFree, speakers 2W x 2, HDMI, DisplayPort, 27G4XE
Also i am not sure if it supports nvidia gpus
https://linustechtips.com/topic/1609702-building-pc/#findComment-16711649
cpu:ryzen 5 5600x
Three things:
1. Stay away from the Corsair CX psu's.
2. 27" is too big for 1080P. Your pixels will look 'stretched' or as we call it 'pixelated'.
3. Any 144+ hz monitor will support G-Sync.
https://linustechtips.com/topic/1609702-building-pc/#findComment-16711651
