Small form factor help
Solved by ThousandBlade,
Good choice on the case, I use the same one, so here's what I think:
That NH-L9x65 is barely enough cooling, I've done that, went to bare die & liquid metal to get just that tiny bit more. Then I switched to AXP-120-x67, It cools better than NH-L9x65. Bigger cooler and use 120mm fan instead.
Also cooler fin direction matters in this case, best to have it vertically. I have high profile rams so I run it heatpipes pointing out the back, had to twist the cooler by force just a tiny bit to clear the power cable extension plug. With low profile ram it should be fine with heatpipes pointing the PSU.
Good luck buddy.
