Budget (including currency): 2 to 2.5k CAD TAX IN. 15%tax
Country: Canada
Hello everyone trying to help a friend build a pc. Previously had one but sadly got destroyed
Located in Canada, Budget would be 2k to 2.5k CAD Tax in. There's about a 15% tax
Light regular usage Mostly basic games : Rivals, OW, some older campaign here and there but would really like to be able to play GTA 6. I know it can be hard to judge performance for a game that isn't out yet looking at recommended specs it would be around i7-12700K/R7 5800X & 4070 12GB/7800XT. He is used to having AMD but doesn't mind either way
will probably go with 2-3TB ish total storage (2.5 ssd & m.2). 32GB Ram
Doesn't mind having an "older" socket for cpu. Doesn't plan on upgrading it. I do have discounts on Storage, RAM & PSU So the emphasis and help we're really here for would be the best Bang for the buck (CPU/GPU/MB) combo Run GTA 6 1080p MAX 144fps. (wifi on MB isn't a necessity)
Already have a case at 175$.
No Monitors, Accessories or OS needed
Thank you very much for your help !
https://linustechtips.com/topic/1608200-new-build-help-please/
Country: Canada
Something like this would be a damn good gaming machine.
https://ca.pcpartpicker.com/list/ZTXGt3
This build can be tweaked of course but just showing that you can get a damn good build for the money, even with Canadian rubles.
The Ryzen 7600 comes with a stock cooler and is amazing for its price.
Check this 10 game average with an RTX 4090 by Hardware Unboxed.
Yeah, its almost at the bottom but it keeps up with CPU's twice its price.
Its the best value CPU on the market right now.
https://linustechtips.com/topic/1608200-new-build-help-please/#findComment-16701166
The B850 boards support PCIe 5.0 for the gpu which is a plus seeing how these new RX 90XX cards support PCIe 5.0.
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($268.98 @ Amazon Canada)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  ($49.99 @ Amazon Canada)
Motherboard: *MSI PRO B850-P WIFI ATX AM5 Motherboard  ($250.98 @ Best Buy Canada)
Memory: *Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($119.99 @ Amazon Canada)
Storage: *Patriot P400 Lite 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($137.99 @ Amazon Canada)
Video Card: Asus PRIME OC Radeon RX 9070 XT 16 GB Video Card  ($1083.50 @ Vuugo)
Power Supply: *be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($159.90 @ Amazon Canada)
Total: $2071.33
Generated by PCPartPicker 2025-04-07 19:12 EDT-0400
https://www.tomshardware.com/software/windows/windows-11-free-or-cheap
https://linustechtips.com/topic/1608200-new-build-help-please/#findComment-16701192
Country: Canada
Hello... I see that you want a new Gaming PC. Given your budget I would recommend the Ryzen 7 5700X3D. This CPU will be your best option for Gaming if you don't ever plan on Upgrading. I don't know what Case you have but I hope that it will fit a Standard ATX Motherboard and has room for extra Fans. The Build I have for you will Play any Game at 1440p and even 4K if needed. I paired the R7 5700X3D with the AMD RX 7800XT. The Motherboard may need to have the BIOS Updated because of Old Stock so that the R7 5700X3D CPU can be used but I don't think you would get an Older Version Board.
Have a Look and let me know what you think. Please feel free to ask me any questions you might have. I can be reached much faster on Discord: Wizardsnapper#2772 as I have this open 24/7.
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
https://ca.pcpartpicker.com/list/qjd7np
CPU: AMD Ryzen 7 5700X3D 3 GHz 8-Core Processor  ($398.00 @ Amazon Canada)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  ($49.90 @ Amazon Canada)
Motherboard: MSI MAG B550 TOMAHAWK MAX WIFI ATX AM4 Motherboard  ($249.99 @ Amazon Canada)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($92.99 @ Amazon Canada)
Storage: TEAMGROUP MP44 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($319.99 @ Amazon Canada)
Video Card: Sapphire PULSE Radeon RX 7800 XT 16 GB Video Card  ($728.00 @ Amazon Canada)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($159.99 @ Amazon Canada)
Case Fan: Thermalright TL-C12C-S X3 66.17 CFM 120 mm Fans 3-Pack  ($20.90 @ Amazon Canada)
Total: $2040.66
https://linustechtips.com/topic/1608200-new-build-help-please/#findComment-16702102
