Installing Operating System without Disk Drive??? Need quick help
HI, I'm buying a laptop with NO disk drive and NO operating system. If you put the windows 7 install disk into a USB optical drive can it still boot from that and install it??? So can i just buy any usb disk drive, plug it in and install windows 7, or do you need an operating system for those usb disk drives to work in the first place
My Gaming Setup: CPU: AMD FX-8350  |  CoolingCooler Master Hyper 212 Evo   Motherboard: Asus M5A97 EVO R2.0   Ram: Corsair 16gb 1600mhz lp (2x8)   GPU: Msi Gtx 970 |  StorageSeagate Barracuda 1tb & Samsung 840 Evo 120gb   PSU: XFX 550w Core Edition   Case: Corsair 760t   OS: Windows 7 Professional 64 bit
Peripherals: Keyboard: Corsair K70 Cherry Mx Brown   Mouse: Corsair M65 Black   Speakers: Microlab FC20 40w 2.1   Monitor: LG 29UM65 29" 2560x1080 IPS 5ms Ultra Wide
That's possible, however, it's easier (and cheaper) to use a flash drive...
damn, I'm late
DEcobra11, on 02 Jun 2014 - 8:30 PM, said:
Use an USB stick...
download an iso and use this for it: http://images2.store.microsoft.com/prod/clustera/framework/w7udt/1.0/en-us/Windows7-USB-DVD-tool.exe
buy a key
BTW, just formatting it to NTFS and copying all contents of ISO into its root there works on some mobos as well.
Any unknown button should be pressed even number of times.
It should work with any USB ODD but a USB flash drive will be faster. If you do choose to go the flash drive route use Universal USB Installer.
Mein Führer... I CAN WALK !!
damn, I'm late
Got ninja'ed. :D:ph34r:
