First post - upgrade suggestions
Go to solution Solved by venomtail,
4 hours ago, Jim_173 said:
Thanks, I assume this suggestion is because of the cache gain?
Grateful for your tip because it made me research more and I can now see why cache is more important than clock speed - particularly for Tarkov.
Am I right in assuming this?
I'm not familiar with Tarkov too much anymore but when it released the 3D CPU's had like 50% extra fps. Devs said they optimised the game since then but not sure by how much. Even when summarising, gaming benefits from bigger cached CPU's such as the 3D ones.
So in this case the 5700X3D will be a great fit and give your GPU a boost you didn't know was still in there.
Budget (including currency): £250-500
Country: UK
Games, programs or workloads that it will be used for: Mainly Tarkov, some GoPro video editing
Other details MSI B450 A Pro board, Ryzen 5 3500X, Arctic 360 AIO, 32gb 3200 Ram, Nvidia 3070 ti founders edition gpu, 850w power supply, Thermaltake Core P6 case, LG 4K 27in monitor.
First post - newbie. New to pc gaming - bit of a potato! Rig has done many hours of work, but now I want to get into Tarkov more seriously and think I need better CPU or board. Recently got the AIO cooler and want to start to learn about overclocking. Be great to max out the gpu and monitor, want to get more FPS and enjoy PC gaming.
https://linustechtips.com/topic/1607948-first-post-upgrade-suggestions/
21 minutes ago, Jim_173 said:
MSI B450 A Pro, Ryzen 5 3600X
Just get a Ryzen 5700X3D while you can. You board should be able to handle it. After that a GPU upgrade. A 3070 will struggle with Tarkov at 4K and a 9070XT would be an ideal upgrade, thankfully your PSU is good enough so it can stay. Just avoid the 900W Powercolor red devil 9070XT. 32GB of RAM is healthy, no need for more.
Pretty solid system otherwise, will age gracefully.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
Quote
Thanks again - sorry to be a pain and ask more questions... I have not upgraded a CPU independently before so am just wanting to make sure im not about to mess something up noob style!
I going to order the CPU but wanted to ask a BIOS question, the version i currently have is as up to date as it can be i believe. But i didn't provide my motherboard full details to begin with...  It is a B450-A PRO MAX , see attached.
Do you know if the new CPU be plug and play on my board and current BIOS?
BIOS updates should be as simple as having an empty USB stick, downloading the BIOS update and placing it on the USB stick. Plug it into the dedicated port, if CPU is compatible update it through BIOS, if not, use BIOS flashback and after that it'll restart itself and you're good to go.
5700X3D compatibility BIOS is the 7B86vMK one that was released in 26/9/23 and as your BIOS is dated 9/2/24 you should be fine but it is a bit weird that I cannot find any BIOS version under the name of 7B86AMS.
You can also upgrade to the latest stable BIOS 7B86vML for a peace of mind.
Thanks again, yes i updated it a month ago before I started playing with overclocking.
I thought BIOS version was weird too, but when I checked the latest ‘7B86vMN2’ download the file name it matches mine so I am confident I’m on very latest and not had any issues.
thanks again. I will let you know how I get on. Super excited to upgrade- probably something I should have done a while back instead of trying to OC my existing!
Well I must say I am blown away by these gains! The CPU was plug and play and give double the previous Cinebench score! FPS improvement is absolutely mega also, I even get 60-80fps at 4K which is nice!
Thanks so much for the tip. Now I’ve just got to improve my mouse & keyboard gaming skills as only recently converted from a lifetime on console/controller!!
Cheers buddy!
