So i will be getting a 750d with my build and, i want the most cooling as possible, and with the 750d i will obviously have enough space for a lot of fans.... What fans should i get for a "budget" price and how many do i need for the best performance. i will be over clocking. TAHNKS
https://linustechtips.com/topic/160765-air-cooling-help/
instead of spending $100 on fans why don't you get a H105 so you can overclock more?
https://linustechtips.com/topic/160765-air-cooling-help/#findComment-2140054
I would Defo get something like the NH-u14s and some noiseblocker blacksilent pros or silverstone air penetrators. You don't need alot of fans mabye 2 intake and 1 exhaust on the top as the CPU cooler can act as an exhaust anyway.
That will give great cooling performance and be very very very quiet.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/160765-air-cooling-help/#findComment-2140789
