Help me ID this case
Solved by strange13930,
1 hour ago, Kirky2k15 said:Got this case from a guy selling cheap cases on FB market place, I got 4 cases from him for £40, not bad.
I've been able to ID all of them except this one as it has no markings on it whatsoever.
Google lens thinks it looks like a Antec NX210 but its not that as the top usb ports and headphone/mic ports are different.
Anyone know what case this is? It feels very cheaply made - I can bend some of the panels very easily.
Thanks
I think this case is the same https://www.reddit.com/r/pcmasterrace/comments/s69gqn/where_to_install_a_hdd_if_theres_no_trayplace_for/
reddit won't load so I can't check for sure. hope it helps
