Recently my idle temps have become really high on my sapphire 7870. Right now it sits at 36 degrees idle compared to around 25 before. For comparison my 8350 is currently at 18 degrees. I've done some testing with heaven and it doesn't break 70 degrees even at 1150 mhz which is pretty good. And yes, I know it is not the winter anymore but I live in southern Canada the temperature is only at 16-17 degrees right now. So, my question is should I be worried or not?
https://linustechtips.com/topic/160565-gpu-idle-temps-high/
Yeah, that's worrisome. I've got an R9 280X with ambient temps TWICE yours (36-38C) as I type this and my idle temp right now is 42C. But if you're running more than one monitor, the GPU clocks might be higher than normal. When I have multiple monitors on, my GPU increases core clocks to 500 Mhz on idle. But it only increases idle temps a few degrees. Not as bad as yours.
Rig: Intel Core i7-2600 / Sapphire R9 280X Dual-X / 2 x 8 GB DDR3-1600 / Seagate Hybrid SSHD 2 TB / FSP500-60APN 500W / 3x 20" 1600x900 LED / 51" Samsung F5000 plasma / Acer K330 LED projector
15.6" Clevo W650SJ: Intel Core i7-4810MQ / Geforce GTX 850M / 1 x 8 GB DDR3-1600 / Hitachi 1 TB 7200 rpm
14" Lenovo Y460: Intel Core i5-520M / Mobility Radeon HD 5650 / 2 x 4 GB DDR3-1333 / Hitachi 500 GB 5400 rpm
https://linustechtips.com/topic/160565-gpu-idle-temps-high/#findComment-2137651
