Basic Mid-Tier Build
5 hours ago, Jasper_Watch said:Budget (including currency): $3000 max
Country: USA
Games, programs or workloads that it will be used for: Corel Painter, Clip Studio, Vegas Pro, AAA titles (including Horizon Forbidden West) at 1440p
I made my PCPartPicker list a year ago, adjusted the GPU and PSU constantly to align with what was actually in stock AND in budget (I'm looking at you SeaSonic FOCUS and ASRock 7900xt). Here's the link to my just the PC components, and here's the list with added peripherals. My question is, will it run smoothly with minimal adjustment? This is my first PC ever, nevertheless building it myself, so I've been riding on the coattails of various Reddit posts for picking my parts. I'm not confident I'm able to adjust and fix on the fly, thus I want to make sure before I fully commit that at least on paper all the parts are decent grade and will work together. I am also planning on upgrading my GPU to a 9070xt when I can catch it in stock, so that's why the PSU is a higher wattage than it needs to be with the listed GPU.
Also if anyone has advise on where to store an external DVD player that's actively connected to the PC, much obliged.
Edit: My main concern is the motherboard, I know I have to update BIOs for the CPU, but I'm also concerned about the RAM (as I already bit the bullet buying the listed sticks). Will the RAM being 6000 without OC hurt the motherboard or the RAM?
I suspect an 9900X would be a better choice.
I did not include the expensive A-RGB 3 fan pack. There are less expensive A-RGB fans. It's not clear to me why one would not also select an A-RGB AIO if one wants lighting.
An 850W ATX 3.x PSU is sufficient for an RX 9070XT.
CPU: AMD Ryzen 9 9900X 4.4 GHz 12-Core Processor ($378.72 @ Amazon)
CPU Cooler: ARCTIC Liquid Freezer III 360 56.3 CFM Liquid CPU Cooler ($129.69 @ Amazon)
Motherboard: MSI B850 GAMING PLUS WIFI ATX AM5 Motherboard ($199.99 @ Amazon)
Memory: Patriot Venom 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory ($139.99 @ Newegg)
Storage: Samsung 990 Pro 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($317.63 @ Amazon)
Storage: Seagate IronWolf Pro 10 TB 3.5" 7200 RPM Internal Hard Drive ($209.00 @ Amazon)
Video Card: MSI GeForce RTX 3060 Ti GAMING X GeForce RTX 3060 Ti 8 GB Video Card
Case: NZXT H9 Flow ATX Mid Tower Case ($154.49 @ Amazon)
Power Supply: SeaSonic VERTEX GX-850 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($149.99 @ B&H)
Total: $1679.50
Generated by PCPartPicker 2025-03-12 23:32 EDT-0400
