PBO Enhancement mode causing issues
Go to solution Solved by OddOod,
1 stick of RAM is an interesting choice. And it's remarkably bad ram at that
33 minutes ago, cat_B0T_Gaming said:
I have not updated BIOS
Definitely check on that. Do not assume.
34 minutes ago, cat_B0T_Gaming said:
I get a blue screen whenever I use PBO enhancement mode.
Use BlueScreenView to interrogate those BSODs. Is there a common failure mode?
35 minutes ago, cat_B0T_Gaming said:
got it put together at Microcenter
Any chance there is a warranty on that assembly? If so, I'd just take it back and have them investigate.
I am having issues with my new PC build(I got it in january, somewhat close to MLK day) whenever I turn on PBO enhancement mode in BIOS. I have had this issue since day one. I put it down to having a defective CPU right out of the box. I get a blue screen whenever I use PBO enhancement mode. I have not updated BIOS, but I assume that the person who put my PC together (I got it put together at Microcenter) did that for me. This is my part list:
Please give me possible fixes.
I AM HUMAN AND I MAKE MISTAKES. FACT CHECK IMPORTANT INFO!
Laptop: Lenovo Thinkpad T450. Desktop CPU: Ryzen 5 8500G, RAM:G.Skill Flare x5 32GB(2X 16GB), MoBo: ASUS PRIME B650M-A WIFI, Case: Inland X1, GPU: ASRock RX 6500 XT 8GB
https://linustechtips.com/topic/1604868-pbo-enhancement-mode-causing-issues/
There is in fact a warranty that I believe is still in effect. Thank you for your help.
Hey, I was on a budget. That's why I use the stock cooler. And why I got Inland SSDs, not samsung.
Totally fair! Just want to point out that a second stick will help the system feel snappy, and if you do elect to upgrade, I'd strongly rec a 2x16 6000 CL30 kit.
Thanks for the advice
