Just get an r9 290x instead.
Outperforms it in every game. The PCS+ version will also keep it nice and cool and quiet: https://geizhals.at/powercolor-radeon-r9-290x-pcs-axr9-290x-4gbd5-ppdh-a1053920.html.
Samung Tab S 8.4
https://linustechtips.com/topic/160473-gtx-780-lightning/#findComment-2136486
I have a 290X lightning (I know it's more expensive, I'm not saying you should get the Lightning specifically) and I can speak for it's awesome, 780 beating performance. I'd recommend either the PCS+ 290X, the Sapphire Tri-X, or the 290X Lightning. I've been able to keep it at 60-65 degrees at stock, and about 70-75 degrees with a 1215MHz core clock and 1550MHz memory clock. ;)
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/160473-gtx-780-lightning/#findComment-2136630
they are both very good, personally its the difference between aesthetics. they both perform very similarly and the only real difference would be depending on how lucky you are with the silicone lottery
If you absolutely need a 780: If you can get a hold of the unnerfed LN2 bios for the 780 Lightning, I'd go for the Lightning. It'll over-clock much better than the Asus. It's pretty much built for LN2.
https://linustechtips.com/topic/160473-gtx-780-lightning/#findComment-2136649
True but you could only really unlock the full power of using LN2 if you are going to be water cooling. With air cooling it will be limited a fair amount by thermals
https://linustechtips.com/topic/160473-gtx-780-lightning/#findComment-2136666
