so I have a semi weird one for at least myself, my place is setup for 5.1 installed in the roof. long story short there is no conduit to where my tv is to where the speaker wire comes out of the roof, I've tested the speakers they all work but I have no way to connect to the tv. so I need a good budget receiver that has Bluetooth.
https://linustechtips.com/topic/1604691-bluetooth-receiver-suggestions/
A lot of your post does not make any sense. I have zero clue what to imagine.
You are in a room, and the TV is in the room with you?
Because... when you say "roof" do you actually mean "ceiling" ? Or are you literally on the roof of a building?
Is the TV mounted on a wall or is it on some kind of media console/furniture and you have easy access to the inputs/outputs?
The center, left, right, and 2x surround speakers, and subwoofer are mounted on the ceiling....???
How are you interfacing with the speakers? How are you testing that they work if you are asking for a receiver?
It would take effort to find a home theater receiver that did not have Bluetooth. It's a standard feature as far as I know and it would be worthless to the manufacturer to not include it by default.
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
